unknown power loss
Old Apr 29, 2012 | 09:21 AM
Roader's Avatar
Compression checks good?
Fuel pressure in spec?
Old Apr 29, 2012 | 08:16 PM
jroxz44's Avatar
Almost A Senior Member
Compression is the next check. It scares me to do thou cause if it low its a bad sign. And fuel pressure idk how to check. Someone also mentions my evap system could be malfunctioning cause i have alot of pressure when i take gas cap off. Idk if thats normal
Old Apr 29, 2012 | 09:32 PM
jroxz44's Avatar
Okay i went for a long drive today and it ran great while i was babying it alot. As soon as i started running it hard it started to lose power. Could that be fuel system problems? Or what else? Hope that little test helps identify my problem. If i baby the car it runs good as soon as i start getting into the peddle alot it starts losing power
Old Apr 30, 2012 | 09:27 AM
Roader's Avatar
Autozone loans out fuel pressure testers. At idle, with the regulator vacuum line disconnnected and plugged, the pressure should be 38 - 46psi; connected it should be 30 - 37psi.
Old May 17, 2012 | 08:18 PM
firefighter44's Avatar
jroxz44, did you ever figure anything out with this? mine is doing the same think "all of a sudden"
Clayvahon
Apr 14, 2009 06:32 PM
lappy35
Jan 29, 2009 06:50 PM
xaznxeclipsex
Sep 10, 2007 02:17 PM
pturnbul
May 3, 2007 02:30 PM
gundalow
Mar 14, 2007 12:53 AM
