Upper Control arm and lower tie rod
Old Apr 20, 2010 | 01:56 PM
kennilope's Avatar
Default Upper Control arm and lower tie rod
Hi how hard it is to install upper control arm and lower tie rod?
I need to replace front and rear.
any special tools require?
Honda accord 94 ex.
Old Apr 20, 2010 | 05:25 PM
Upper control arm is pretty simple. There is no lower tie-rod. Do you mean inner and outer tie-rod or the lower ball joint?
The only special tool that you will need is something to separate the ball joint from the knuckle for the upper control arm. You can rent a pitman puller from places like autozone for free. I have used the smaller one for the upper ball joint and the tie-rod end. The bigger one will work for the lower ball joint if you have to replace it.
If you meant the lower ball joint, then you will have to press in the new one. It may be simpler to remove the knuckle and have a machine shop do that part of it. Also, the axle nut will have to be removed which will require a 36mm socket.
cukaracha
Apr 9, 2015 10:29 PM
thesoymilk
May 27, 2013 12:39 PM
bamaccord
May 22, 2009 03:41 PM
jpdfly
Dec 13, 2008 11:18 AM
jpdfly
Dec 12, 2008 08:50 AM
