Upper control arm torque specs for 2000 accord?
Some of you may remember me posting a thread a while back about an odd noise that I would hear while driving that was NOT consistent with rotational speed. I found out that it was the bushings on the upper control arm, so I'm replacing the entire control arm as a new one comes with two new bushings and a new ball joint.
I need the torque specs for the bushings and the ball joint castle nut if anyone has them. Appreciate it.
I'll do a write up with pictures when I do the job. Waiting on the part to come in the mail. Kinda wondering if I should have just replaced both control arms or not. If one side is bad, the other may be close.
castle nut spec: 29-35 ft lbs
upper arm: 47 ft lbs
hint: you can fully torque the ball joint, but for the upper control arm wait until the vehicle is back on the ground and jounce the front suspension a couple times. then torque to spec.
cukaracha
Sep 14, 2014 11:09 PM
JonJon13926
Jul 8, 2013 11:54 AM
curvenut
Jan 31, 2013 08:36 PM
