valve cover bolt/nut
Old Jan 8, 2011 | 07:12 PM
stevie's Avatar
Default valve cover bolt/nut help
i just got a 91 honda accord. The guy befor me snapped the valve cover bolt/nut and i was reading it cost's a couple hundred dollars and i just dont have that much money off hand to fix any suggestions ?
Old Jan 8, 2011 | 08:45 PM
EXV6NIGHTHAWK's Avatar
Buy the bolt from the nearest dealership, and replace it yourself. The bolt/stud probably costs less than $5. Those little cap nuts do not require much torque (10ftlbs maybe), so you have to be careful. They snap really easy.
Make sure you get the right bolt/stud, because they have different lengths. You probably don't have the nut anymore, so you will probably have to get that too. This link may help you to determine which bolt needs replacing
http://www.bkhondaparts.com/billkay/...temcomp=Engine
Old Jan 8, 2011 | 09:24 PM
stevie's Avatar
ok thanks alot it helps
swordfish7769
Nov 23, 2015 11:19 PM
adrian750
May 16, 2013 05:25 PM
mrolgren
Oct 27, 2009 07:31 AM
ndrew2505
Oct 24, 2008 12:50 PM
johnjokela
Mar 30, 2008 09:11 PM
