Vehicle speed pulse wire
Old Nov 27, 2007 | 03:18 PM
falkore24's Avatar
Default RE: Vehicle speed pulse wire
Spaz ..... look at the V-AFC installation instructions. This may be something for your Wiki.
Old Nov 27, 2007 | 04:01 PM
sir_nasty's Avatar
ORIGINAL: klrspz
Does anyone have a readout for the ECU pins? I can't seem to find anything clear and evident in my minor searching...
bleh, i'll look again in a bit
Generic Pinout OBD II
http://en.wikipedia.org/wiki/On-Board_Diagnostics
H22a Pinout OBDII
http://www.honda-tech.com/zerothread?id=918703
Old Dec 1, 2007 | 10:33 AM
HondatechAV6's Avatar
the vehicle speed output is given directly from the pcm to the guage. it's a blue/white wire. it run from the pcm and is then spliced off to the drivers multiplex, guage assembly, passenger under dash fuse box and the cruise control unit.
personally, i'd recommend taking it from the passenger underdash fuse box since it simply does nothing there. it's run there and then not used. so you just cut the wire from the connector and splice in or just plug in a terminal wire, whatever.
heres the box
heres a pic showing which connector you want to find - #9
here is the connector itself, there should be a blue/white wire in terminal C12.
here's where the problem comes in. it's showing that there is a blue/white wire in that terminal for a/t and manual transmissions and that it's not used on either one, but in the detailed connector information it shows that wire is only on a manual trans model. so it may or may not be there. if it is, use it. if it's not i'll find something to help.
01SilverAccord
Jun 24, 2011 08:20 PM
sfcool
Nov 2, 2007 10:42 AM
Sliom001
Sep 24, 2007 09:56 AM
ukbuckstop
May 2, 2007 08:56 PM
PJ_STYLES_95AccordEx
Aug 9, 2006 09:51 PM
