Very technical timing question.
Old Jan 12, 2008 | 08:56 AM
67coronet383
Default Very technical timing question.
On an F22A4 ('90 EX) there are two balance shafts of course. One on the left side of the crank(radiator side), one on the right side(firewall side of motor). They are both of course driven by the balance shaft belt.
Now, the one on the left is driven from the belt going on the gear that is directly bolted to the end of the balance shaft. The other shaft, on the right side, however, is not. It has the belt gear which is meshed with another gear that is on the balance shaft, so there is two gears, and so the balance shaft can spin in the opposite direction of the opposing shaft.
Now that you know what I'm talking about, the question is how do you mesh the gears in time on the right balance shaft?
Old Jan 12, 2008 | 09:14 AM
HondatechAV6's Avatar
Default RE: Very technical timing question.
ok, first install a suitable balancer shaft holder into themaintanence hole. now prep and install the drive gear assembly so that after it's installed the mark on the pulley is pointed at about 5 o clock(it lines up with a mark on the block).
get it?
Old Jan 12, 2008 | 09:36 AM
67coronet383
That is exactly what I have been looking for. Thank you very much.
Old Jan 12, 2008 | 09:40 AM
please send check or money order to hondatechav6.... [8D]
Apr 24, 2014 03:24 PM
Sparkplugs.com
Oct 31, 2010 03:16 PM
ArcticHonda
Dec 26, 2008 03:34 PM
CHUSTZ
Dec 14, 2008 11:46 AM
