Vibration Issue
Starts vibration when at 65mph, intermittent at times, it happens at different speeds. Checked tire balance and rims.
lplaza
2003 Honda Accord, 4Cyl, Automatic
lplaza
Last edited by lplaza; Jun 23, 2011 at 05:17 PM. Reason: Following thread post rules
I would put the front end of the car on jack stands. Turn the steering wheel until it locks.
Grab the front tire, and try to push/pull at the 9/3 o'clock positions. Also try the 12/6 o'clock positions. There should be very little movement of the tire (less than a quarter inch). If someone holds the steering wheel, there should be no play. If there is play, then try to find the component that is showing movement.
Also, do you get pulsation when using the brakes at any speed?
art vandelay
Aug 2, 2010 09:29 AM
