Vibration Issue
Old Jun 23, 2011 | 03:48 PM
lplaza's Avatar
Default 2003 Honda Accord LX Automatic - Vibration Issue
Starts vibration when at 65mph, intermittent at times, it happens at different speeds. Checked tire balance and rims.
lplaza
2003 Honda Accord, 4Cyl, Automatic
Last edited by lplaza; Jun 23, 2011 at 05:17 PM. Reason: Following thread post rules
Old Jun 23, 2011 | 06:12 PM
Is the vibration still there if you rotate the tires?
Old Jun 24, 2011 | 04:18 PM
lplaza's Avatar
Yes it is.
Old Jun 24, 2011 | 05:08 PM
I would put the front end of the car on jack stands. Turn the steering wheel until it locks.
Grab the front tire, and try to push/pull at the 9/3 o'clock positions. Also try the 12/6 o'clock positions. There should be very little movement of the tire (less than a quarter inch). If someone holds the steering wheel, there should be no play. If there is play, then try to find the component that is showing movement.
Also, do you get pulsation when using the brakes at any speed?
Old Jun 24, 2011 | 05:51 PM
upintheclouds90's Avatar
Does the car only vibrate when the gas pedal is pushed down? I had this problem on my 4 door 2003 Honda Accord and ended up replacing both axles to get rid of the problem. (I resorted to a mechanic and paid $400 OUCH)
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
janicesaccord
Mar 4, 2006 08:18 PM
