Vibration in steering wheel at all speeds
Old Apr 9, 2023 | 05:40 PM
xHypa's Avatar
Default Vibration in steering wheel at all speeds
Hi,
I tried to search around but couldn't find any solution to this.
As title says, I am currently experiencing a vibration in my steering wheel at all speeds, I feel it more in the bottom half of the steering wheel, handbrake lever, and also in my brake pedal ( not pressed, just resting my foot against it )? I feel like this is a rotational vibration.
I had my car inspected and the mechanic said suspension wise, your car is perfect.
A few things to note is that, my rear driver side caliper is seized and I had my tires replaced recently.
I will be changing my rear caliper and pads + front pads - this week.
I will also be rotating my tires, from front to back - to see if that makes any difference.
Old Apr 10, 2023 | 04:24 PM
Fix the seized caliper. I'd lean towards a tire balance issue. If rotating the tires changes the vibration, you'll probably need to get the tires balanced again.
Old Apr 21, 2023 | 09:07 PM
xHypa's Avatar
Update - Changed rear caliper, rotor and pads along with front rotor and pads.
Solved majority of the vibration, it is very faint now.
I am wondering if it is the tires? I have yet to swap the rear to front to see if that changes anything.
Old Apr 22, 2023 | 11:35 AM
xHypa's Avatar
I do want to add that, my steering wheel does not shake or anything, I just feel a vibration that feels like a rubbing/grinding feeling that starts at around 10 mph / 20 kmh.
I did swap my tires recently and I am starting to think that they are bad.
SE2012hags
Apr 7, 2017 04:03 AM
cukaracha
Jun 20, 2016 06:32 PM
ahutch67
Mar 26, 2011 09:52 AM
gagy82
Mar 3, 2009 06:32 PM
Carmen91
Mar 27, 2008 10:13 AM
