Vibrations while idoling
Old Apr 20, 2011 | 10:52 PM
Maystg's Avatar
Default Vibrations while idoling
I recently got a 1997 Honda Accord EX Sedan with the VTEC for my first car, and it idols pretty rough. Is that normal with the older VTECs? Or what?
Old Apr 21, 2011 | 02:00 AM
The idle should be pretty stable. How are the maintenance items like the distributor cap, rotor, spark plugs? Have you had the car scanned for codes? Most parts stores will do this free of charge. Your connector is behind the ash tray.
Old Apr 21, 2011 | 11:04 AM
Maystg's Avatar
Well we did have one of the most trusted mechanics in our area check it out. But I was planning on checking to spark plugs today. What exactly do you mean by rotors? and what should I look for with the distributor cap?
Old Apr 21, 2011 | 01:44 PM
The distributor rotor is the part of the distributor that spins and makes contact with the distributor cap connections.
You want to make sure the metal contacts in side the distributor cap are not worn out. The edge of the rotor should look in decent shape. Check for any fine cracks in the distributor cap as well.
Old Apr 21, 2011 | 06:50 PM
Maystg's Avatar
Oh okay. Thank you.
kinneyrhs
Apr 29, 2008 09:38 AM
klrspz
Jan 16, 2008 08:33 PM
ranst20
Apr 6, 2006 02:17 AM
dktkd
Sep 2, 2005 12:38 AM
