Vss help
Old Aug 9, 2014 | 03:08 PM
  #51
Is the 5v reading based on the TPS connector's by touching only the Grn/Blu wire and the Yel/Blu wire with the voltmeter's leads?
Old Aug 9, 2014 | 03:45 PM
  #52
CarSick's Avatar
I have 5v at the tps connector, i have 4.8v on the orange vss wire...ky on
Old Aug 9, 2014 | 03:48 PM
  #53
CarSick's Avatar
Yes black lead on GREEN and red lead on YELLOW/key on...5v
Black leadon GRN and red lead on orange vss wire i get just under 5v
Old Aug 9, 2014 | 04:13 PM
  #54
Okay, Grn/Blu wire (sensor ground from ECM) seems good; no short or open in wiring. Btw: Grn/Blu is a green insulation colored wire with a blue stripe running through it.
Plug TPS and VSS back in.
At the ECM connector C460 (see picture), check voltage reading at pin 6 (red/Blk wire) coming from TPS with ignition ON. You may have to backprobe.
At the ECM connector C459, check voltage reading at pin 13 (orange wire) coming from VSS with ignition ON.
At the TCM connector C461 (see different picture), check voltage reading at pin 5 (orange wire) coming from VSS with ignition ON.
Last edited by redbull-1; Aug 14, 2014 at 10:46 PM. Reason: Correction on ECM connector for VSS. images removed
Old Aug 9, 2014 | 05:26 PM
  #55
CarSick's Avatar
At the ECM connector C460, check voltage reading at pin 13 (orange wire) coming from VSS with ignition ON.
on
My Orange VSS wire goes into the Ecu through plug B (c259) 11.2 (vss/tps plugged in)
I have a red wire w a black stripe at c260 .5v with key on
Orange wire at TCM shows the samé 11.20 v. ..key on
Old Aug 9, 2014 | 05:55 PM
  #56
Originally Posted by CarSick
on
1. Yes, VSS orange wire should be plug B (connector C459).
The VSS voltage reading is too high at both ECM and TCM. Try the replacement ECM you have to re-check the VSS voltage reading there. If it still doesn't change after the different ECM, we'll have to check the orange wiring for a short.
2. The TPS red/blk wire voltage appears okay at the TPS and at the connector C460 at the ECM. Not sure why it is throwing a TPS code.
Some of this is kind of repeating the earlier posts in this thread.
Old Aug 9, 2014 | 06:07 PM
  #57
CarSick's Avatar
11.15v at Ecu on orange wire (replacement Ecu)...vss plugged
4.85v at ECU on orange wire with vss unplugged
Old Aug 9, 2014 | 06:19 PM
  #58
So, no difference in voltage for VSS wire with original or replacement ECM?
Just to rule it out something going on between the TCM and ECM causing it, try unplugging the connector for the TCM and plugging back in the connector for the ECM. Any change in voltage on VSS orange wire?
Old Aug 9, 2014 | 09:27 PM
  #59
CarSick's Avatar
no change in voltage
TCM Unplugged, Key on, Vss unplugged, I have 4.8v at orange
when i pull the ecm fuse volts on orange at vss connector (unplugged) drop to 4.7
The numbers are the same when i plug the TCM
Old Aug 9, 2014 | 10:13 PM
  #60
Under most circumstances, it would seem the ECM is the issue; but, you tried a different ECM and it is the same result with the VSS.
Which ECM fuse did you pull, the one under the hood or under the dash? That way I can see which wire that is.
