Vss help
Old Aug 8, 2014 | 06:21 PM
  #41
CarSick's Avatar
cel Code 7
d4 flashes code 4. ....with original ecu...tach good
Im checking my TPS or trying too, Should i have 5v at the TPS with the gas pedal no depressed? Its got tree wires,
Between Battery grnd and the YELLOW wire i get 5v...NO THROTTLE
Between GRN (With Black probe) and the other probe on the RED wire i get .5v with NO THROTTLE
Between GREEN AND YELLOW I get 5v....NO THROTTLE
Between Battery grnd and the Red wire I get 4.15v @ WOT
Between Battery grnd and the YELLOW wire I get 5v at @ WOT
Between GREEN (With Black probe) and YELLOW I get 5v At@The WOT
Old Aug 8, 2014 | 07:06 PM
  #42
CarSick's Avatar
im getting code p1791 with my scanner
Old Aug 8, 2014 | 07:09 PM
  #43
For the TPS:
Terminal no. 1 - Grn/Blu wire is sensor ground from ECM
Terminal no. 2 - Red/Blk wire is the TPS inputs to ECM and TCM
Terminal no. 3 - Yel/Blu wire is reference voltage from ECM (should be 5 volts)
Closed throttle (accelerator not depressed):
Terminal no. 2 - Red/Blk wire should be approx. 0.5 volts.
Wide Open Throttle (WOT):
Terminal no. 2 - Red/Blk wire should be approx. 4.5 volts.
Old Aug 8, 2014 | 07:21 PM
  #44
CarSick's Avatar
WOT Im getting 4.32v at The Red/blck. ...grounded at Battery
Where ya at in No Cal?
Old Aug 8, 2014 | 09:07 PM
  #45
Your TPS may be okay. I am wondering whether you have a short on the ECM sensor ground wire.
Looking at the circuit diagrams, the ECM provides sensor ground on the Grn/Blu wire to the following components:
  • Throttle Position Sensor
  • EGR valve lift sensor
  • Engine Coolant Temperature (ECT) sensor
  • Front Heated O2 sensor
  • Intake Air Temperature sensor
In addition,the Grn/Blu wire is connected to the blue Service Check Connector that you jumped to retrieve trouble codes.
Try this:
With the TPS unplugged, with the voltmeter's black lead on the Grn/Blu wire connector cavity terminal, check to see whether you get a voltage reading on when you touch the voltmeter's red lead to the Yel/Blu wire cavity terminal; with the ignition ON.
If you don't get a voltage reading doing that, you may have a short in the Grn/Blu wire.
Old Aug 9, 2014 | 02:06 PM
  #46
CarSick's Avatar
I have 4.8v between the service connecter pins with the key on...
Old Aug 9, 2014 | 02:14 PM
  #47
Do the test at the TPS connector, between Grn/Blu wire connector cavity terminal and the Yel/Blu wire cavity terminal; with the ignition ON.
Do not jump the service check connector while you do this.
Old Aug 9, 2014 | 02:20 PM
  #48
CarSick's Avatar
I need to redo that test, i left the tps plugged in. ..im supposed to take this reading at the two pin blie service conmector right? ..it has a blue and a red wire
Old Aug 9, 2014 | 02:27 PM
  #49
No, you're taking the voltage reading at the connector for the TPS. The Grn/Blu wire and the Yel/Blu wire.
Do not jump the blue SCS connector, leave it alone.
Old Aug 9, 2014 | 03:04 PM
  #50
CarSick's Avatar
I have 5v at the tps connector, i have 4.8v on the orange vss wire...ky on
