Vss help
Old Aug 9, 2014 | 10:22 PM
  #61
CarSick's Avatar
Under most circumstances, it would seem the ECM is the issue; but, you tried a different ECM and it is the same result with the VSS.
Which ECM fuse did you pull, the one under the hood or under the dash? That way I can see which wire that is.
I pulled the one under the hood
Old Aug 9, 2014 | 10:32 PM
  #62
Examine closely the wiring harness and connector terminals for ECM connector C459 (connector B). Also, look closely at the Blu/Red wire coming from pin 5 to see if there is some damage on the wire somewhere that may have bare wire touching another wire.
Looking at the circuit diagram, I can't think of anything else from all the things we went through in this thread that may be causing the issue.
joe94wag
Dec 7, 2014 12:08 AM
rberens60
Jan 8, 2012 12:31 PM
chrisjames105
Aug 17, 2011 08:06 PM
loadder
Mar 3, 2011 08:52 PM
comptoncarl
Feb 8, 2007 03:04 PM
