VTC Actuator installation question
I am changing the timing chain, guides and ATC actuator on a 2003 Honda Accord 2.4L Vetch. When I try to align the timing chain to the corresponding marks on the camshaft and crank shaft gears the camshafts seem to have pressure on them and want to rotate so that the chain jumps about two links unless I hold the chain tight. Is this normal?
