!! Vtec or not vtec !!
Old Mar 26, 2016 | 01:04 AM
Rm240666's Avatar
Originally Posted by PAhonda
You have a vtec engine in the vehicle.
Lets verify the VIN for the trim level.
1HGCD553....
If your VIN has the number 3,4 on the bolt red digit then it is a LX. If there is a 5/6 it is an EX.
Last digits are 5533.. LX?....
Old Mar 26, 2016 | 11:03 AM
It says LX without anti-lock brakes.
Old Mar 26, 2016 | 05:26 PM
Rm240666's Avatar
Yes. No anti lock brakes... it's an LX.
I don't believe this model comes with vtec... correct?
Old Mar 26, 2016 | 06:43 PM
The LX did not come with v-tec. I suspect someone replaced the engine with a Japanese vtec engine. I'm guessing the PCM is for the LX, because it is not giving a check engine light. To verify, the OEM PCM part number will be on a sticker on the PCM. It will start with 37820-.....
Old Mar 28, 2016 | 01:12 PM
Rm240666's Avatar
Question.. where are the pcm's in the 96 accord?
Old Mar 28, 2016 | 06:57 PM
The pcm is under the carpet near the firewall on the passenger side. You pull back the carpet, and there is a metal plate you unbolt.
This video is for an Acura CL, but is almost identical to your accord to get to the PCM.
Old Mar 29, 2016 | 10:51 PM
  #17
Rm240666's Avatar
Quick question, I'm looking to possibly change out the timing belt also some other stuff. Do I buy parts for a vtec or non vtec accord?
Old Mar 30, 2016 | 10:26 PM
  #18
Rm240666's Avatar
Sorry.. another question.. in my album pictures it's titled "misc part" cam someone please take a look and let me know what this miscellaneous metal tube hole is? I have a manual tranny so I'm at a loss.. thanks all!!
Old Mar 31, 2016 | 12:14 AM
  #19
buy the belt for the vtec.
I think that picture is a vent on the transmission. It probably should have a tube that bends down on it so nothing gets into the transmission.
Old Apr 1, 2016 | 01:59 AM
  #20
Rm240666's Avatar
When the heads are swapped from non vtec to vtec are timing gears/belt changed also?
