!! Vtec or not vtec !!
Old Apr 24, 2016 | 07:01 PM
  #41
Rm240666's Avatar
Originally Posted by PAhonda
You may want to shoot Poorman a message to get his ideas.
I'd think that you could hook up an oil pressure gauge in place of the vtec oil pressure switch.
This model doesn't have a pressure switch just a bolt in its place. Do I remove the bolt to check the oil pressure? Thanks again, I will shoot him a message for ideas!
Old Apr 24, 2016 | 08:23 PM
  #42
The 96 shop manual that 10 mm bolt can be removed to attach a pressure gauge.
With the solenoid unplugged, you should have less than 7 psi pressure. The solenoid has 1 wire going to it (green/yellow). If you give that wire 12V, the pressure should be greater than 36 psi. The testing procedure says to test at 1000, 2000, and 4000 rpm.
Old Apr 24, 2016 | 10:37 PM
  #43
Rm240666's Avatar
Thanks for the info!! Can this test be done in park/neutral or does it have to be in drive?
Old Apr 24, 2016 | 11:05 PM
  #44
Park or neutral should be fine.
skyfire322
Dec 27, 2013 10:39 AM
kshellz
Oct 24, 2012 10:51 AM
trukid21
May 4, 2012 02:44 PM
FarRockAccord
18
Feb 1, 2008 06:36 PM
94coupeaccord
Feb 7, 2007 05:01 AM
