!! Vtec or not vtec !!
Old Apr 16, 2016 | 05:40 AM
  #31
Actually the timing belt IS DIFFERENT between the two, cam gear is different between the two causing the timing belt to be different (the "tooth" count is different).
Don't worry with the dist - yes there is an internal and external coil dist but really doesn't matter. The wire plugs to the two different dist is different but really doesn't matter.....just re-wire the two and they can be interchanged.
Old Apr 17, 2016 | 08:45 PM
  #32
Rm240666's Avatar
So if I purchase a timing belt kit with water pump and all, since just my heads are changed do I buy a kit for vtec or non vtec? I have a LX. Do I get the EX KIT?
Old Apr 17, 2016 | 09:56 PM
  #33
There are still a few unanswered questions in this thread.
#1: We still aren't sure if the head was swapped or the whole engine. Get the entire number stamped on the engine block (and cylinder head) and call your local dealership to see if they can verify the source vehicle for the engine.
#2: Are you planning on swapping ECUs, or swapping cylinder heads?
#3: What was the OEM part number on the ECU currently running in your car?
Old Apr 18, 2016 | 01:44 AM
  #34
Rm240666's Avatar
1.Your right, should the numbers be up front noticeable?
2. I plan on swapping ecu and wiring up solenoid.
3.I need to check on this but does the metal bracket covering need to come off to see the numbers? Thanks again...
This is what I got as far #s:
copy & paste in your browser⤵
https://goo.gl/photos/vRXAygtbixWKyipH8 https://goo.gl/photos/FctPAdGrZd2nKkq77 https://goo.gl/photos/jynBcmVmuUG6mcMu7
Old Apr 24, 2016 | 12:01 AM
  #35
Rm240666's Avatar
Any other thoughts?
Old Apr 24, 2016 | 12:07 AM
  #36
The picture with F22B stamped into the engine is the important one. The numbers below it are the serial number for the engine. You mentioned earlier that you have a H22 head, so where did you get that information?
Old Apr 24, 2016 | 12:37 AM
  #37
Rm240666's Avatar
Just noticed that also. Sorry meant it had "HA" stamped..so the ecu is for LX, checked earlier and confirmed. Head is vtec. Do I call a honda dealer now and confirm the engone serial number? And will it determine if just the heads were replaced or if it is a full engine swap?
Old Apr 24, 2016 | 12:56 AM
  #38
Yeah, find out as much as possible about the vehicle that engine came out of. The VIN for the vehicle would be helpful.
I always thought the F22B engine was a DOHC, but the picture of your engine is a SOHC cylinder head.
Old Apr 24, 2016 | 05:12 PM
  #39
Rm240666's Avatar
Ok so.. called dealer and engine belongs to my year and model (96 honda accord lx)... so it looks like it was just a head swap. Ecu is original. Vtec solenoid is not connected. Only thing now I'm unsure of is if the oil orifice in the block was removed..is there anyway without removing head to know if there's oil flow for the solenoid?
Old Apr 24, 2016 | 06:11 PM
  #40
You may want to shoot Poorman a message to get his ideas.
I'd think that you could hook up an oil pressure gauge in place of the vtec oil pressure switch.
