Vtec Problems
Old Oct 26, 2012 | 03:10 PM
xlino's Avatar
Default Vtec Problems
Hello. I have a 98 Accord 2.3L and I think I have a problem with my Vtec Solenoid.
I get in my friends Civic and I can hear the Engine sound different at a higher RPM and her says that is Vtec.
That has never happened with my car. So I was looking around and people say they suggest taking off the VTec Solenoid and cleaning it with Brake Cleaner. replace the gaskets as well. So my question is: Is there a way to test my Vtec Solenoid? Before I take off the Solenoid do I have to drain the motor from Engine Oil? The solenoid is right next to the block so I am worried that if I take it off all the oil will come out. Any Help Please?
Old Oct 26, 2012 | 03:26 PM
You don't have to drain engine oil to remove VTEC solenoid. Oil only flows under pressure when engine is running. You may lose a tiny amount. If solenoid were not working, an engine code would be set. It could be blocked, but this seems unlikely.
Old Oct 26, 2012 | 10:03 PM
If that's a civic Si (DOHC engine) then her vtec is a lot different than an Accord's vtec. Yours is a lot more subtle, & switches at lower RPM too. Some B16 (civic si) engines have 2-stage intake manifolds and when the secondaries open up all the kiddies think THAT is the vtec sound.
trukid21
May 4, 2012 02:44 PM
FarRockAccord
18
Feb 1, 2008 06:36 PM
94coupeaccord
Feb 7, 2007 05:01 AM
KimberlyC
Apr 16, 2006 11:51 AM
