Water Pump Replacement 2007 Honda Accord V6
Old Apr 12, 2018 | 05:08 PM
kayg's Avatar
Default Water Pump Replacement 2007 Honda Accord V6
Hi,
I was informed that I am leaking motor oil from the seals by my timing belt. Since I am already going to pay for labor to replace those seals, I think I am going to replace the water pump as well. In addition, to replacing the water pump, what else should I replace? I want to go down to the dealer to pick the essential parts for this replcaement.. I know they will say I have to replace a hundred parts, but if someone can give me an idea of what are the main parts you want to focus on, that would help me out a lot. I am trying to stay OEM for these replacements (and stay away from water pump kits) since it's a vital component to my engine. My car is a Honda Accord EX 4 door V6 with 111,000 miles on it.
Old Apr 12, 2018 | 08:50 PM
Timing belt, water pump, seals, the tensioner pulley, idler pulley, and the hydraulic tensioner.
Old Apr 13, 2018 | 11:41 AM
Seanjordan20's Avatar
PAhonda nailed it. Those are the parts I would replace if I was changing seals. Especially the hydraulic tensioner and timing belt. Also if your belt has not been changed replace it. I chose the Bando belt which is OEM for the 07
Old Apr 13, 2018 | 01:09 PM
irhunter's Avatar
Originally Posted by PAhonda
seals
+1^^
Main and cam seals. Does this motor have balance shafts? And, is there a seal associated with the oil pump?
zacharyzoosh
Jun 30, 2013 12:42 AM
piggylover1985
May 27, 2011 05:28 PM
islander300zx
May 26, 2011 06:22 PM
mark95
May 18, 2009 11:47 AM
quietgiant
Feb 3, 2007 04:10 AM
