Weird AC Issue on 05 Accord
Old Jun 13, 2013 | 02:56 PM
alexkurbiel's Avatar
Unhappy Weird AC Issue on 05 Accord
Only the passenger side of the cabin AC deflectors blow the cold air. The driver side air is always the outside temperature. What am I supposed to check for?
Old Jun 13, 2013 | 08:00 PM
Low charge is usual reason for this problem. Evaporator is not getting enough refrigerant to cool entire evaporator. Check system pressures, if they're low you've confirmed low charge.
Old Jun 14, 2013 | 11:17 AM
Dr. Drivability's Avatar
if it's dual climate control, it can be an issue with the blend door. need to retrieve codes and then go from there.
misterdeez
Jul 27, 2013 09:38 AM
MrAdams21
Jun 28, 2013 08:08 PM
hcker2000
May 25, 2013 09:40 AM
kenlandrum
Dec 13, 2011 07:10 AM
bobkat2105
May 24, 2011 02:28 AM
