Weird No-Crank Problem- 2001 EX
Old Dec 30, 2013 | 02:04 PM
Milanodan's Avatar
Default Weird No-Crank Problem- 2001 EX
On rare occasions have to turn key to start position several times before it would crank. No solenoid clicks. Then yesterday it would NOT crank after many tries, including leaving car, locking/unlocking cycles, park/neutral etc., nothing.
Then I tried hand pushing it to a better parking place, car did not want to roll--flat pavement. Only managed to shove it about one inch. Tried again, car fired right up.
Car has since started right up several times since. Any ideas?
Old Dec 30, 2013 | 03:13 PM
Faulty, intermittent ignition switch assys are common in many Hondas, but 1998-2002 had a recall on this system I believe.
Confirmation would be absence of any dash panel lights when no-start occurs and checking for 12v on blk/yel wire at distributor connector w/ keyswitch in On position. No power indicates faulty ignition switch assy.
Easy DIY, usually < 1/2 hr. See DIY forum for guidance and look at youtube videos for additional tips.
Old Dec 30, 2013 | 03:24 PM
Milanodan's Avatar
Thanks! The dash lights stay on w/o dimming during the no-starts.
Old Dec 30, 2013 | 04:35 PM
I meant the system lights; Check Engine, Alt, Oil Pressure, etc.
Old Dec 30, 2013 | 06:45 PM
Milanodan's Avatar
Yes, those warning lights stayed on.
Old Dec 31, 2013 | 01:11 AM
holmesnmanny's Avatar
when it doesn't start, remove from the starter the power lead(the smaller one not the bigger one coming from the battery) and test for 12v....if none put that lead back, then jumper with a paper clip the clutch switch connector(if manual) or neutral safety switch connector(if auto) after removing the connector and see if it starts..if it does you've found the culprit...if not then you need to check for power at the starter relay connector
if you did get battery then the issue is the starter...google "larry b's starter contacts" to see what bad starter contacts look like...then pull your starter and see if they look bad...if not then just replace the starter...if they look worn then get some starter contacts
yes you will need to find out where these parts are on your car..do some googling unless someone here can help i don't have a helms for your car
Old Jan 2, 2014 | 07:53 AM
Milanodan's Avatar
After a few days of instantly cranking, this AM it took 2 tries. I heard something click under the hood. Sounded more like a relay than the starter solenoid.
Old Jan 2, 2014 | 07:56 AM
Starter solenoid failure is common problem on Honda/Acura starters. Check battery cables and battery carefully for corrosion/defects.
Old May 17, 2014 | 06:39 PM
Milanodan's Avatar
It was the starter solenoid. Replaced the whole starter.
Melissa Mcdowell
Apr 20, 2014 08:45 AM
spacechimp
Nov 22, 2013 09:21 AM
tuabuelo
May 21, 2010 08:14 PM
cybersnake
Apr 15, 2006 08:36 AM
calenatar
Mar 10, 2006 03:23 PM
