Werid Start Problem?
Old Nov 19, 2008 | 09:49 AM
HondaRacer4Vtec's Avatar
Default Werid Start Problem?
Hi everyone wondering if i could get some help
Got a 2000 honda accord 4cyl coupe with f23a4 ulev engine. I get this werid problem when i try to start the car warm. for instances when i try to start the car when the engine is warm i starts and then two seconds later the car bogs down and shuts off. Usualy what i do to cure the problem is i hit the car with gas when i start it then when i get it into gear i try to make a quick run in order for it not to bog down. but once the car is running it runs great. Iam thinking its some kind of sensor or maybe fuel pump. Anyone else have any other suggestions? Thx
Old Nov 19, 2008 | 10:02 AM
cjdm98's Avatar
Default RE: Werid Start Problem?
I had the same problem, took out the main relay,it was bad. Put a new one in and the problem hasn't occurred since.
Old Nov 19, 2008 | 10:10 AM
hondadude's Avatar
You didn't read the Service News letters that your service manager gave you. LOL
There is a known problem with warm starts. 98+ Accords.
Try this; Turn on the key, let the fuel pump run 3 seconds for full pressure, push the gas pedal about 1/2 way [allows more air] then crank.
I think the newer owners manual has a description of opening the throttle plate1/2 wayfor warm starts.
Ican't rule out that there could be some other problem, but I like to try simple fixes first.
How old are the spark plugs BTW?
Old Nov 21, 2008 | 08:40 AM
Spark plugs are pretty old i should get those replaced soon. Thx for the help guys appreciate it will try and see what happens.
Tony1M
Nov 6, 2023 08:29 PM
bpethomas
Jun 5, 2012 10:47 AM
kellysa111
May 1, 2009 08:35 AM
brickballer
Apr 18, 2008 04:25 PM
HondaRacer4Vtec
Jun 20, 2007 06:43 AM
