Wet Floor in Drivers Space
Old Aug 22, 2012 | 08:55 AM
KO23's Avatar
Default Wet Floor in Drivers Space
I live in Florida and apparently when it rains I encounter my drivers space floor soaked. I know is only when it rains because when its sunny is perfectly fine, Even when I wach my car. I dont know from where is coming what so ever. For now what I ve done is putting a large towel at the floor so it picks up the moisture and put 2 set of floor carpets.
Any suggestions, ideas or a possible diagnose for this?
Thanks!
Old Aug 22, 2012 | 05:16 PM
One possibility is the sunroof drain tube for that corner. It runs down the windshield pillar & out, so maybe the hose is moved out of it's proper position. I can't get the parts pictures right now, so can't be more specific.
Since it doesn't happen when you wash the car, but only when you drive, how about a leak through the floor? Only comes from water spraying up from the front wheel. Peel back the carpeting and/or have a good look from underneath the car.
Old Aug 22, 2012 | 09:09 PM
As Jim stated, could be the drain tube
Attached Thumbnails Wet Floor in Drivers Space-6th-gen-moonroof-drain-frt.jpg
Old Aug 23, 2012 | 07:11 AM
KO23's Avatar
Thanks for the info. Is highly appreciated!
I have a gut feeling it is a leak through the floor but I will check both possibilities.
Thanks again and have a nice day.
Old Aug 24, 2012 | 09:26 PM
KO23's Avatar
If is the drain tube, how much would it cost to replace or buy the tube? If any idea
Old Aug 25, 2012 | 10:49 AM
Most of the time the tube/drain valve gets clogged and just needs cleaning - "A" in the picture.
Some will use a compressor and blow air into the tube to try to clear it. Some will feed something soft (like weed eater string) down the tube to try to clear it.
Not sure on the 6th gens - this works on the 3rds - sometimes you can remove the plastic inner wheel well liner and get to the valve where it "pokes" thru the sheet metal - then clean the valve from that side.
mattimeo_boyd
Jul 20, 2021 08:25 PM
Str8fp
Nov 15, 2011 10:52 AM
Honda Enthusiast
Feb 15, 2011 08:43 PM
Audioz
Dec 16, 2006 01:01 AM
Trav20
Oct 15, 2006 04:03 AM
