What is best OBD II scanning tool for Hondas?
Old Nov 28, 2017 | 12:30 PM
rtaksokhan's Avatar
Default What is best OBD II scanning tool for Hondas?
Just curious to know what everybody favours and why? Is there a diagnostic OBD scanner that works best over others for Hondas? (I have a 2001 Honda Accord 2.3 Liter ULEV)
Requirement for me: Live or real time scanning and freeze frame capability to capture and display all engine management vitals such as:
Short Term & Long Term Fuel trims,
sensor voltage readings (O2, TPS, EGR, Temperature, etc. )
If you could format response:
Scanner Make:
Scanner Model:
Scanner Price:
Personal use (DIY):
Commercial use (shop, repairs as side job etc.):
Reports downloadable to PC: Y or N?
Ease of Use (scale of 1 to 10):
Old Nov 28, 2017 | 01:08 PM
Jet sitter's Avatar
I don't know what is the best, but the one they sell at Harbor Freight works fine for me. Buy the one with ABS, it's around $107.00 that's how I found my wheel sensor problem.
Old Nov 30, 2017 | 09:08 AM
Jp267's Avatar
I've had good luck with the Bluetooth Elm based Kiwi and the dash command app on Android.
Last edited by Jp267; Nov 30, 2017 at 09:09 AM. Reason: Edit: Don't think it has ABS and that is a glaring omission.
Old Dec 3, 2017 | 07:44 AM
Seanjordan20's Avatar
I've been using OBD fusion from the App Store and a $15 ELM OBDII wifi adapter for years with no problems. This setup is only for simple diagnostics. The more complex (airbag, continuity test, etc) will need a better reader.
Old Dec 3, 2017 | 08:20 AM
Jp267's Avatar
I bought a power probe kit a year ago as well for my F250. If anyone is ever trying to diagnose an electrical gremlin, I fully recommend it. It will look for relay faults, bad fuses, continuity from the fuse and relay sockets, ground issues and a million other things. I have found it works great on any car, and is especially good, if you are installing electronic aftermarket parts such as stereos etc. If will find wires that have switched continuity for things like reverse cameras. For example the switched wire for the reverse lights etc., without studying all the wiring schematics.
caliazaccord
Feb 7, 2013 10:59 PM
sooty305
Jul 6, 2012 07:14 PM
dragonle87
Oct 5, 2009 09:53 AM
dragonle87
Oct 4, 2009 08:54 PM
FlyLow
May 8, 2006 06:12 AM
