what fluid goes where?
Old May 12, 2012 | 06:06 PM
firefighter44's Avatar
Almost A Senior Member
Default what fluid goes where?
I need a online copy of a owners manual for a 96 accord ex, 2.2 vtec, with manual trans and or a diagram showing where to fill each thing under the hood also what each reservoir is for as some of them i dont recognize since this is my first honda. any links or info would be great!
I've also heard the manual trans on these are hydrolic and iassume that means there is a hydro reservoir for that?
Old May 12, 2012 | 06:14 PM
crispin's Avatar
super easy on your car
with hood open facing car
Brake fluid - in front of driver on firewall
Power Steering - drivers side close to the front of the car, about 8 inches away from headlight
Oil - in valve cover
Coolant - passenger side next to headlight
Transmission cannot be done from under hood
Old May 12, 2012 | 08:34 PM
See attached pics for:
  • Engine oil
... to be continued...
Attached Thumbnails what fluid goes where?-engine-oil.jpg   what fluid goes where?-engine-oil-part-2.jpg   what fluid goes where?-engine-oil-part-3.jpg   what fluid goes where?-engine-oil-part-4.jpg   what fluid goes where?-engine-oil-part-5.jpg
Old May 12, 2012 | 08:37 PM
...continued...
  • Engine oil (continued)
  • Manual transmission fluid
  • Brake Fluid
  • Clutch Fluid
..to be continued...
Attached Thumbnails what fluid goes where?-engine-oil-part-6.jpg   what fluid goes where?-manual-transmission-fluid.jpg   what fluid goes where?-brake-clutch-fluid-part-1.jpg   what fluid goes where?-brake-fluid-part.jpg   what fluid goes where?-clutch-fluid.jpg
Old May 12, 2012 | 08:42 PM
...conclusion.
  • Coolant
  • Power steering fluid
  • Windshield washer fluid
Attached Thumbnails what fluid goes where?-coolant.jpg   what fluid goes where?-power-steering-fluid.jpg   what fluid goes where?-power-steering-fluid-part-2.jpg   what fluid goes where?-windshield-washer-fluid.jpg
Old May 12, 2012 | 09:03 PM
thanks guys for that help!
Old May 12, 2012 | 11:03 PM
You can also go to the common diy thread on top of the gen tech help forum. There is a link to online shop manuals. You can download a 94 accord shop manual as a pdf and it is almost identical to your 96 accord.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
slayerfan
Aug 13, 2006 05:08 AM
deserthonda
Jul 29, 2006 03:07 AM
