What to look for - Used 2005 Accord EX-L V6
Old Apr 4, 2018 | 01:18 AM
ABNTGR's Avatar
Question What to look for - Used 2005 Accord EX-L V6
Hi All,
Thanks in advance for any advice...I did do a search on here and found a few things to keep in mind. I have the opportunity to get an 05 EXL V6 with Nav with only 72k miles on it.
What are some things I should be aware of? Are their known issues to check out?
It's at a reputable dealer and they have done most, if not all, of the maintenance and Carfax is clean so I'm feeling pretty good about it, But, it is 14 years old!
What is the real in town mileage you guys are getting with the V6?
Thanks again for any thoughts!
Old Apr 4, 2018 | 08:08 AM
Seanjordan20's Avatar
I'm assuming it is an automatic you are looking at. I would check for transmission issues. These are sensitive transmissions and if not taken care of will break before time. Also the compressor. Make sure it is clicking on. There is not to much to look at on these cars. These engines are solid. Just change the oil when you get it. Other than that change out fluids you deem necessary to change. I have a manual because of the issues Honda was have with the automatic transmissions since 99.
Old Apr 4, 2018 | 08:50 AM
ABNTGR's Avatar
Yes, it's a automatic. Thanks!
Old Apr 4, 2018 | 04:47 PM
The Toecutter's Avatar
Actually some of the 03's still had issues. The 04's on are pretty reliable as Honda wasn't making 2 different AT's at that time. Honda had also gone thru it, and fixed most of the problems with it.
mbereck
Jun 16, 2016 07:58 AM
05hondanewb
Feb 22, 2012 08:13 PM
dwm1225
Mar 30, 2010 02:05 PM
PhillyTurboSix
May 16, 2008 09:03 PM
