what is the name of this part?
Old Sep 24, 2011 | 02:07 AM
xu111's Avatar
Default what is the name of this part?
My car is 2003 Accord LX 4 cylinder Automatic with 75,000 miles. It runs well and no code so far. One day, I notice there is a part (circled in red in the pic) which is on the driver's side of the engine, connected to the engine by a narrow tube and also connected to intake air duct by a wide tube.
What is the name of this part? I also noticed there is a small tube (red arrow) protruding from this circled part. Close by, there is a separate protruding of intake air tube (yellow arrow). Are those two things supposed to be connected or not? Thanks a lot
Old Sep 24, 2011 | 04:30 AM
The part is called an air flow chamber. The metal line leading into it is a breather tube. It is #2 in the picture below. I would say the rubber part of the intake snorkel should be connected to that air flow chamber. It probably became disconnected when the air filter was changed.
Old Sep 24, 2011 | 12:38 PM
Good call and your right as rain again... Twins, lol
Old Sep 24, 2011 | 08:21 PM
Yeah, the small connection to the intake duct needs to be stuck back together. (Red & yellow arrows in your picture #3)
Old Oct 1, 2011 | 10:20 PM
xu111's Avatar
Thanks a lot! They were put back together.
Old Feb 2, 2018 | 06:48 PM
Garcia0824's Avatar
Default Need this part asap!
Causing check engine light to turn on and I've been told its getting too much oxygen not enough gas. No auto zone worker can tell me what the part is called. Someone said air flow chamber but anything i google or look up at an auto parts store does not match that part. I need this fixed asap as my plates a due in march
Old Feb 4, 2018 | 07:56 AM
Double check me, you didn't give exact year/engine/trim combo so I'm kind of guessing based upon the original posters car information/
"breather joint rubber" is what Honda calls it - 17152-RAA-A00. Should be about $3 at the dealer. I highly doubt you will find this a normal "parts store".
Old Jul 19, 2021 | 11:35 AM
romereom's Avatar
the Air Flow Tube Rubber Mount
fourbanger
Aug 26, 2009 11:52 PM
dagrotts
Jun 19, 2008 11:22 AM
nicolaselias
Mar 24, 2008 12:12 PM
sia_simba
Sep 12, 2007 06:58 AM
Chucho_Xv3
Jul 27, 2007 12:17 AM
