What is it? Overflowing PS fluid & squealing
Old Oct 3, 2006 | 05:25 PM
jill hughes
Default What is it? Overflowing PS fluid & squealing
'90 Honda Accord- power steering reservoir has been overflowing and I get a high pitched squeal as I turn the wheel L or R while driving (not while dry-stearing).
Old Oct 3, 2006 | 05:31 PM
Slusher's Avatar
Default RE: What is it? Overflowing PS fluid & squealing
It sounds like your belt is slipping. When you turn the wheel and it screechs your probably not going to fast, like parking? The belt could be worn or it needs to be adjusted. The resevoir overflows MAYBE because the pump itself is bad and fluid builds up inside the resevoir and doesn't circulate. Chances are the two problems are related.
Old Oct 3, 2006 | 05:45 PM
WhyNotFab's Avatar
My pump makes a clicking noise all the time, and a grinding noise when I go to turn while going slow.. sometimes the PS works, sometimes not.. fluid bubbles and overflows, I found out it's the bearing inside my pump. We might have the same problem, I found a few pumps on ebay for less than $50 Shipped though. Let us know how it goes!
Old Oct 3, 2006 | 06:22 PM
jill hughes
Squeal happens particularily when driving close to highway speeds on curvy roads (I try to get it to happen in front of a mechanic driving slow and it's hard to duplicate).
Old Oct 3, 2006 | 07:09 PM
Slusher's Avatar
I really think that you have the same problem as WhyNotFab. At highways speeds the engine is turning over faster than at idkle and the pump then runs into trouble.
Old Apr 3, 2011 | 07:48 PM
King Dragon's Avatar
Default how to fix....my ps problem....?
Does anyone know how to change the ps pump and belt....? Please try and let me know in details for I am newbie working on my car.... A 1991 honda accord lx stwg... So much help is needed.... Thanks....
Old Apr 3, 2011 | 08:34 PM
Here are some pdfs that will help. Just copy and paste into your browser.
Pump Removal:
media.honda.co.uk/car/owner/media/manuals/accordManual/400/11-31.pdf
Drain/Refill Fluid:
media.honda.co.uk/car/owner/media/manuals/accordManual/400/11-19.pdf
62maxx
Oct 18, 2015 08:20 AM
Donda
May 10, 2013 12:11 PM
nickmg555
May 9, 2013 05:36 PM
oneloudskunk
Aug 6, 2011 07:45 PM
fireballer44
Jan 24, 2007 04:12 AM
