What part is this from undercarriage?
Old Oct 10, 2012 | 06:39 PM
mjkenyon's Avatar
Default What part is this from undercarriage?
I recently was driving when I heard something dragging underneath my car. I pulled over to see this piece hanging from my undercarriage by one bolt. I was able to remove it, however I have a few questions.
1) What is this part called?
2) Is it safe to drive without it? I will bring it to a mechanic this weekend but in the meantime I need to commute to work.
Thanks for the help.
Attached Thumbnails What part is this from undercarriage?-accord_undercarriage.jpg
Old Oct 10, 2012 | 06:40 PM
mjkenyon's Avatar
I have an '06 Accord.
Old Oct 10, 2012 | 07:32 PM
Probably the lower cover (heat shield) for the catalytic converter. Is the upper cover still there? The lower and upper covers (heat shield) go around the catalytic converter.
It's okay to drive without the cover.
Old Oct 10, 2012 | 07:35 PM
Gt-R's Avatar
There is no probaly to it. Thats one of the heat covers for your Honda's cat.
The bottom heat shield really isn't needed. but the top cat you do need cause it protects the underside of the car from if the cat should bounce and hit the car.
Old Oct 10, 2012 | 10:06 PM
mjkenyon's Avatar
Thanks for the advice.
I am a bit concerned, though, that this piece just completely rusted out to the point of just falling off. I live in the Northeast, but I get my undercarriage washed frequently in the winter to prevent salt buildup. My car has about 120K miles on it.
Old Oct 11, 2012 | 12:36 AM
Gt-R's Avatar
It could have had help. Just driving the car round, scraping it on speed bumpers,curbs. Anything could have helped it along. You do need to make sure your top shield is still mounted right though.
Old Oct 11, 2012 | 08:01 AM
One thing you can do is place that lower shield back in place & fit steel hose clamps around the whole thing to hold it in place. I've done that & it lasted for a few years before a "proper" repair was needed.
THM
Dec 15, 2011 05:18 PM
ydelamater
Aug 3, 2009 07:58 PM
crvone
Oct 25, 2007 12:05 AM
iamiles
Feb 28, 2007 10:23 PM
Thep
May 4, 2005 09:38 PM
