What should I look for? Have 99 drivetrain
Old Oct 7, 2011 | 05:50 PM
sidponcho's Avatar
Default What should I look for? Have 99 drivetrain
Hi All,
My daughter totalled her 99 Accord last Sunday. She is OK, but no insurance to cover collision
I'm looking for a decent body to that needs a drivetrain because her's ran great.
What year Accord should I be looking for other than the obvious '99 that will easily take the 4 cyl?
THANKS
Old Oct 7, 2011 | 08:00 PM
I think the 98-02 will work. The other accords that had F-series engines are the 90-93 and the 94-97, but I don't know how easy it would be to swap your engine and transmission into those bodies.
Old Oct 7, 2011 | 09:31 PM
For 1998-2002 there's 3 different 4-cyl engines. For easiest swap, the car should match the engine.
- non-VTEC (Accord DX)
- VTEC (LX & EX)
- ULEV-VTEC (California car that might have moved out to the east coast?)
If you can do some wiring, just make sure if it's ULEV or not.
DX (non-VTEC) can swap with LX or EX (VTEC non-ULEV) without too much trouble but you have to add a few wires for VTEC. Or leave them hanging if your daughter's engine is a non-VTEC. Grab the ECU from your daughter's car before the crusher gets it.
Swapping a ULEV engine into a non-ULEV car or vice-versa would be a big hassle. Wiring harness is a lot different.
Old Oct 8, 2011 | 05:58 AM
sidponcho's Avatar
Thanks for the replys! Its a ULEV. Now I know what to look for.
Next question: After the accident, there is no battery power at all to the car. Before pulling it, I'd like to start the engine. The battery and cables are intact and I pulled the radiator support out with my truck. The air bags never went off. Is there a cut-off switch or something that would have tripped in the accident preventing battery power to the car?
Attached Thumbnails What should I look for?  Have 99 drivetrain-img00689-20111008-0654.jpg   What should I look for?  Have 99 drivetrain-img00690-20111008-0654.jpg
Old Oct 8, 2011 | 06:43 AM
piggylover1985's Avatar
I did a ULEV motor swapped into a non ULEV, and i have no problem with it so far, only a couple of small things are different.
Old Oct 8, 2011 | 07:59 AM
No power to anything, I'd check the main fuses in the underhood fuse panel (do the haz lights work).
Old Oct 8, 2011 | 05:25 PM
sidponcho's Avatar
Interesting.....the hazards do work....will check fuse tomorrow!
Old Oct 9, 2011 | 07:12 AM
Not going to dig out the wire diagrams yet, but most of the time the haz lights use a totally different circuit than most of the other things on the car.
...check the fuses, the "main" ones I was talking about are the higher amp (40 and up) ones with the window on top.
Good luck and glad everyone is ok.
Old Oct 9, 2011 | 09:01 PM
Maybe Piggylover will share some more details, but here's what I think...
If you can't find a ULEV car, try to find a VTEC car (LX or EX). Use the exhaust manifold and front O2 sensor from the non-ULEV car. Along with the PCM from the non-ULEV car. That basically turns your engine into a non-ULEV VTEC. (You could be clever & swap the valve covers so it doesn't say ULEV.)
davidg99
May 5, 2011 11:59 PM
spider1999
Nov 14, 2007 06:51 PM
Bearcat
Apr 18, 2007 05:12 PM
2.2ex965spd
Dec 30, 2006 12:33 AM
