what size brake line does a 99 accord use
Old May 7, 2011 | 06:55 PM
Cessna172's Avatar
Default what size brake line does a 99 accord use
Hello, i had a steel brake line rupture on me this morning, and need to replace it. First off is there a quick temp. fix to this problem, like sleeving it with something and clamping it off, and second, what size diameter line do they use on a 99 accord for the steel line to the rear brakes, just have to get it home so it can be repaired.
Old May 7, 2011 | 07:30 PM
Google "honda brake line size" for link. It says the size is 3/16" tubing and nut is 10x1mm. you will need a bender, cutter and flare tool which can be rented from auto parts such as autozone, et al.
Not as easy as you might think.
Warning, it there's one hole it may rupture again if you splice a piece in place. I had this happen on a Dodge truck that was driven in salt water on coast.
Old May 7, 2011 | 07:51 PM
Cessna172's Avatar
ARE there any connections between the and back that a new piece could be put in or a way to splice one between fittings
Old May 8, 2011 | 05:43 AM
The don't use splice fittings and you'll have to find some tubing fittings to perform a splice.
Old Apr 27, 2024 | 06:22 PM
chambersc2's Avatar
Default Where do I get the brake line from
Ik the size is 3/16 10m x 1.0 but where would I get them I seen it on autozone but when I went in to get it they had the wrong size to the part number and i went in the back to look for the right one but it was no where to be seen.
robbierob02
Jan 4, 2015 06:27 PM
eduard
May 9, 2013 12:11 AM
Michellekaplan74
Mar 30, 2012 11:41 AM
PhilipK
Oct 31, 2007 08:28 PM
blaz72282
Mar 31, 2007 11:50 PM
