Where is the AC switch? 95 Accord v6
Old Jul 12, 2011 | 05:31 PM
chrisjames105's Avatar
Default Where is the AC switch? 95 Accord v6
*I have the v6 model and its a pain in the *** to find stuff.
Ok so my clutch isnt kicking on and I want to try jumping the switch to see if it will kick on. I know theres two switches and I found one of them but the one I found is for the AC fan. I need to find the "pressure switch" or "cycle switch" whatever the name of it is. Pictures would be so appreciated!
Old Jul 12, 2011 | 06:16 PM
The pressure switch will be on the high pressure line (thinner tube) close to the compressor.
It is #14 in the pic below.
Old Jul 12, 2011 | 06:45 PM
Thanks, I found that picture too on Majestic Honda but I cant seem to figure out where that would be in the car.
Old Jul 12, 2011 | 06:54 PM
I believe #19 close to #14 bolts into the bottom of the a/c condenser (radiator-looking part in front of the real radiator). Just follow the smaller line towards the compressor.
That sensor looks to be close to the a/c compressor.
If you have a volt meter, you can check for voltage on one of the wires going to the pressure switch. The other wire should be closed circuit (~zero resistance to ground) with the a/c switch turned on and the blower inside the car turned on.
You can also test for voltage going to the compressor.
Old Jul 12, 2011 | 06:58 PM
Ok I will look down there tomorrow and see if I found it. Thanks.
look under the battery tray.........
EDIT: reading gets the best of me some days...this is the V6. On the 4 cyl it is under the battery tray and the battery is on the pass side....sorry....if everything is "flipped" _battery on yours on the drivers side....maybe its under that?
Matthew Kniss
Jun 30, 2014 06:00 PM
funkyguy
May 16, 2012 11:22 AM
RedCruiser
Jan 17, 2007 02:02 PM
jhburns
Dec 13, 2006 11:10 PM
62maxx
Oct 26, 2006 11:23 PM
