Where is the antenna routed?
I have a 94 accord lx coupe. The back window got broken out before I bought it and it used to have the built in antenna but the new window does not have it. I bought a mast antenna but I dont want run a whole new cable if I dont have to so I am trying to find out where the antenna cable is so I can just plug the new antenna into the existing cable.
Normally antenna cable is on driver's side, behind trunk interior trim cover. There should be an opening in the LR fender just below the rear window. I recently replaced the power antenna w/ a flexible mast antenna at that location. I wasn't aware that Honda offered a window-embedded antenna in 94. Perhaps an aftermarket item.
billyloon
Jul 30, 2006 07:13 PM
