Where is the antenna routed?
Old Feb 24, 2008 | 07:24 PM
lfbs01
Default Where is the antenna routed?
I have a 94 accord lx coupe. The back window got broken out before I bought it and it used to have the built in antenna but the new window does not have it. I bought a mast antenna but I dont want run a whole new cable if I dont have to so I am trying to find out where the antenna cable is so I can just plug the new antenna into the existing cable.
Old Feb 25, 2008 | 07:23 AM
Default RE: Where is the antenna routed?
Normally antenna cable is on driver's side, behind trunk interior trim cover. There should be an opening in the LR fender just below the rear window. I recently replaced the power antenna w/ a flexible mast antenna at that location. I wasn't aware that Honda offered a window-embedded antenna in 94. Perhaps an aftermarket item.
Old Feb 25, 2008 | 10:55 AM
smaglik's Avatar
the coupes of the 5th gen had emdedded antennae. the sedans did not.
Old Feb 25, 2008 | 11:50 AM
lfbs01
Yeah it used to be built into the window but since I replaced the window its not now I have to run a new antenna.
Eauxkie
Sep 27, 2006 08:18 PM
billyloon
Jul 30, 2006 07:13 PM
msmiz
Dec 22, 2005 09:05 PM
stigedis
Dec 4, 2005 10:12 PM
pgopalak
Dec 17, 2004 03:30 PM
