where is the A/C clutch relay on 96 accord
Old Mar 15, 2008 | 04:57 PM
roadstump's Avatar
Default where is the A/C clutch relay on 96 accord
My A/C is not blowing cold. I am not hearing a click or feeling the engine surge when I click the A/C button on and off. Both 7.5 amp fuses under dash check good so I want to check the clutch relay.
According to Chilton manual the A/C clutch relay and condenser fan relay are mounted separately from the under hood relay and fuse box. Even though there is a picture in the manual I cannot find it.
Roadstump
Old Mar 15, 2008 | 05:04 PM
Default RE: where is the A/C clutch relay on 96 accord
They are on the driver's side near the A/C condensor fan. I am almost positive they mounted on a bracket that is bolted to either the radiator support or A/C fan housing.
Old Mar 15, 2008 | 05:09 PM
hondadude's Avatar
When the freon leaks out the system pressure drops the pressureswitch opens the circuitto keep the A/C from turning on.
Maybe the compressor and relay are okay and you need to have the system recharged?
Old Mar 15, 2008 | 07:18 PM
roadstump's Avatar
Well, I searched both the drivers and passenger side front corners and I see nothing that looks like a relay. I must be blind. I will stop by and have someone check the refrigerant level, hoping that's all it is. Maybe I'll snap some pics to show you guys.
Old Mar 15, 2008 | 10:26 PM
Chiovnidca's Avatar
Look around near the left headlight.
Old Mar 15, 2008 | 11:59 PM
There should be a metal bracket coming off where the a/c condensor fan is bolted to the radiator. The two relays are attached to that. They are basically to the right of the radiator if you are looking at the engine from the front bumper.
Old Mar 20, 2016 | 09:14 AM
Mr.Fixit's Avatar
Default Clutch relay.
Standing in front of the car, facing the motor. You can find it on a "push on" clipp right beside the fan wire harness connect. Note: some times they are not tight and fall off while driving, in that case you will find the "relay on the end of the wires, hanging halfway down be side The fan.
Old Mar 22, 2016 | 08:10 PM
holmesnmanny's Avatar
I can't say that I've ever heard of an ac clutch relay ever being the cause of ac problems. Number 1 cause is a leak, no more referigerant.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
greg05
Aug 31, 2009 05:32 PM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
