Where can I buy those 2 small screws for the ignition coil terminals?
Old Jul 19, 2012 | 01:05 PM
letsclique's Avatar
Default Where can I buy those 2 small screws for the ignition coil terminals?
I replaced my ignition coil a couple months ago with a new one (new one didn't come with new screws). I noticed one of the old small Phillips screws that screws down a terminal to the ignition coil was stripped. I would like to replace it with a new one (and have some for back up). I called a salvage yard I go to and the man said they only sell the whole distributor. Ace wasn't any help, just said to look in the screw section and I read from another Honda forum that Ace doesn't have a screw that small.
Also, if I can find some replacement screws, does anyone know if you would put threadlock, etc., on the threads just to make sure the screw doesn't shake loose from engine vibration, etc?
Old Jul 19, 2012 | 02:04 PM
Dr. Drivability's Avatar
don't know, but when you find them don't put threadlock on them. i think they are brass? correct?
Old Jul 19, 2012 | 02:32 PM
JJC's Avatar
JJC
Being an old parts man I can tell u that these sm problems can eat up lots of time on the job and time being money, well there u go. You can call around to the auto parts companies but more than likely u will have to match it up. Then you end up at Home Depole, Lowes or look for a Bolt and Nut Company in the phone book. Note: Get a bolt, nut, and screw gauge for SAE and Metric to keep around. You can see them at hardware stores hanging around for your use (and their's)... get your own and make it easy next time. Good luck
Old Jul 19, 2012 | 09:24 PM
What year/engine are we talking about here?
Old Jul 20, 2012 | 09:59 AM
letsclique's Avatar
Sorry, I forgot to add this. It's a 1990 Honda Accord DX, 2.2 L, Manual.
Yes, I think they look like brass screws.
Old Jul 20, 2012 | 10:03 PM
Looks like the online Honda dealers are selling them for ~.50 ?
93892-04016-08 for example, check this part number......be sure to verify my lookup.
phantomgrey92
Oct 9, 2013 04:45 PM
letsclique
Feb 16, 2013 10:11 PM
Redcap
May 11, 2008 04:33 PM
new2honda
Feb 7, 2007 12:21 PM
