Where is temp. sensor for the gauge on a 2013 2.4?
Old Jan 12, 2018 | 04:49 PM
jlatessa's Avatar
Default Where is temp. sensor for the gauge on a 2013 2.4?
Car shows very slow warm-up on gauge, removed thermostat and tested in a boiling pot, seemed to operate OK,
replaced anyway, same result
Suspect sensor because I'm getting sufficient cabin heat.
Anyone know a source for finding the sensor among all the gizmos the engine has?
I have no shop manual...
Thanks, Joe
Old Jan 12, 2018 | 09:37 PM
The gauge on your dash is controlled by the engine computer (aka PCM). The PCM gets the coolant temperature from 2 different coolant temperature sensors. I'm not sure which sensor (or both) feeds into your gauge.
Is there any chance you live in a cold climate and have the heat turned on full blast when first starting the car? Your inside heat acts as a radiator and my be cooling the coolant to heat the cabin of your car.
Old Jan 13, 2018 | 10:02 AM
Generally, the PCM uses ECT Sensor 2 for the gauge control output. ECT Sensor 2 is on the engine.
Old Jan 14, 2018 | 08:57 AM
jlatessa's Avatar
Thanks Red Bull, is it the one I see on the passenger side of the head, mounted vertically?
It has a two lead supply.
I thought a two lead is on/off only and one lead is resistor type for gauges???
Thanks, Joe
Old Jan 14, 2018 | 09:46 AM
The one-wire senders were for the gauge, up until 2003 or somewhere around there. Sometimes we see statements like that, strictly true only for the year/model being discussed in that thread. Honda has had maybe 4 or 5 different configurations of sensors over how many years has the Accord existed...
Old Jan 14, 2018 | 06:02 PM
I had a typo in my initial post, it is ECT Sensor 1, not Sensor 2 (Sensor 2 is at the bottom of the radiator).
On a 4 cylinder, ECT sensor 1 should be on the driver's side.
The harness connector to ECT Sensor 1 has two wires (One is pink, the other Gray).
Attached Thumbnails Where is temp. sensor for the gauge on a 2013 2.4?-ect-sensor-1.jpg
Old Jan 15, 2018 | 07:46 AM
jlatessa's Avatar
After removing the two plastic shrouds, I see what looks to be a sensor on the cast water manifold
housing for all the water inlet/outlets, I'm assuming that's it.
Not going to be fun removing but that's the norm on these cars now!!
So I can go to Honda and ask for the ECT sensor 1 and they won't look at me like I'm a dolt??
Thanks, Joe
Old Jan 18, 2018 | 08:18 AM
jlatessa's Avatar
Well, I found the sensor on "Hondapartscheap" for $41 shipped.
Coming from Cal. so probably a week before I see it, I'll update on the success....or not!
Joe
draker
Aug 24, 2025 07:16 PM
scrapmetaljoe
Aug 30, 2019 09:05 AM
ivans10
May 21, 2016 10:09 PM
pirulino23
Nov 10, 2010 06:18 PM
raf105
Sep 28, 2007 02:55 PM
