Where is VSS located (GEN 5)
Old Sep 24, 2013 | 08:48 PM
crvone's Avatar
Default Where is VSS located (GEN 5)
Hi,
The speedometer on my 1995 Accord (4cyl Vtec with MT) is acting erratic. Sometimes it looks dead for 5 minutes or so then acts normal (this can happen any time, at the start or while driving on the freeway, etc.)
I though I'd check the Vehicle Speed Sensor, but I keep looking in the engine bay and can't locate it. Could someone post an image/diagram of exact location of it on this model... I thank you in advance.
Old Sep 24, 2013 | 08:52 PM
If you don't have a Check Engine Light on and the cruise control works, it probably is not the VSS. It may be the speedometer circuit board.
The VSS is located on top of the transmission. At the distributor, look down to the transmission. It should be a little bit further back on the transmission, near the thermostat housing.
Old Sep 25, 2013 | 09:18 AM
Dr. Drivability's Avatar
here ya go, but like redbull said, it needs a proper diagnosis.
Old Sep 25, 2013 | 12:25 PM
crvone's Avatar
RedBull/Doc,
Thanks a lot. Good point, I'll ckeck. So if the cruise control works while driving when the speedometer needle is reading 0 then it's not the VSS? But perhaps contacts/solders in the back of speedometer are loose/cracked etc? I am not sure that is something I can fix on my own.
Old Sep 25, 2013 | 02:27 PM
Good post guys...
Old Sep 25, 2013 | 07:29 PM
Originally Posted by crvone
RedBull/Doc,
Yes, if the cruise control works when the speedo is "acting up", then the issue is with the PCB of the speedo unit.
Old Sep 26, 2013 | 12:12 PM
crvone's Avatar
Today the speedometer worked for about 2 minutes then completely died. I was on the freeway and turned on the cruise control and it functioned. So it seems to be time for a speedomater replacement.
How tough is it to get it out?
Old Sep 26, 2013 | 03:23 PM
Go download the service manual (see sticky at top of this forum section, "Common DIY and Other Info Threads") or follow these guides. Note: From the guides below, you do not need to remove the climate control, just remove the center console and unscrew the 2 Philips screws under the center console for the black dash panel. Leave the climate control hooked up.
ledautomotive.com/guide.php?id_cms=40
ledautomotive.com/guide.php?id_cms=44
Honda-Tech - View Single Post - Speedo Works randomly
62maxx
Feb 10, 2008 02:23 PM
xaznxeclipsex
Sep 28, 2007 05:07 PM
comptoncarl
Feb 8, 2007 03:04 PM
62maxx
Oct 26, 2006 11:23 PM
bovabrandon
May 16, 2006 01:53 PM
