White smoke coming from radiator
Old Jan 20, 2022 | 07:17 PM
levandosky's Avatar
Default White smoke coming from radiator
Hello, I have a 98 Accord 2.3 4 cyl. VTECHHHH
anyways, bought the car from auction and i’ve been working on it for a while.
There’s white smoke coming from the radiator, it’s quite clear it’s leaking antifreeze as well and the fans won’t turn on at all…
here’s a video of what’s going on, after driving it’s starts smoking wayyyyyy more but that’s about 10 minutes of idling, temp gauge never goes above middle so i don’t think engine is overheating at all
https://youtu.be/k7Jm7AVBXJ8
Old Jan 20, 2022 | 11:35 PM
You need to troubleshoot the radiator/cooling system for leaks and why the fans won't turn on.
For the cooling system, some autoparts stores have a loaner tool to pressure test the radiator. You put the adapter on the radiator cap and pump the radiator with air pressure to about 16 psi. The system should hold 16 psi for a while. Do this when the engine is cold. From your video, it looks like the crimp from the metal to the plastic is leaking which happened on my TSX. There is also an adapter for the radiator cap, where the radiator cap should hold pressure until about 16 psi then release pressure. If you find the radiator is leaking, I'd recommend a Denso brand radiator.
For the fans, start the engine and turn on the a/c. Let us know which fan(s) turn on, if any. You can also try unplugging the radiator fan switch on or near the thermostat housing. The sensor should have a green plastic connector. The wire colors going to the fan switch are green and black. Short the electrical connector on the engine harness, start the car, and let us know which fan(s) turn(s) on.
Old Jan 21, 2022 | 05:52 PM
levandosky's Avatar
Thank you very much!
You’ve fixed my “non working” fans, as soon as i put a paper clip in that ect sensor both of the fans were running great, I ordered a new ect switch and it arrives in a couple days. As for the radiator I ordered a new one but it’s going to take a while to arrive, do you think it’s unsafe to drive with the leaky radiator I have now? Maybe i can just keep a gallon of anti freeze for the week until I replace it, or is that a terrible idea…?
Old Jan 22, 2022 | 11:55 AM
I'd minimize driving the car as much as possible. Do short trips until you figure out how much coolant you need to add. Running the car hot can warp the cylinder head and cause a head gasket leak. That is a ton of work an $ to fix
When driving, have a gallon of coolant and fill the actual radiator when the engine is cold. Watch the temp gauge in the car. If it goes above the normal ~1/3 mark, turn on your heat full blast with outside air to help cool the engine.
Not sure about supply chain on the radiator, but a u-pull-it junkyard may have one in decent shape that would be a temporary fix. It is a gable, but might be worth a shot until your new one arrives. Rockauto may have a Denso radiator for sale, maybe ebay?
levandosky
Jan 10, 2022 10:27 AM
AWH8DBABE
May 24, 2013 06:52 PM
JESSI MADISON
Jul 9, 2012 06:39 PM
bpethomas
Jun 3, 2012 11:10 PM
Sunnysideup
Mar 29, 2010 09:14 AM
