Why will my 98 Honda accord not crank unless I flood the gas pedal?
Ok so my 98 accord will not crank unless I'm holding down the gas pedal, and if I try to let it idle by taking my foot off the pedal it shuts off. However if I continually keep my foot on the gas pedal it will continue running. Please help!!
Symptom suggests air starvation at idle leading to cutoff. Suggest cleaning Idle Air Control Valve (IACV) and throttle plate/bore w/ throttle body cleaner. Check that IACV is working by applying 12V and ground to connector.
No codes would indicate the IACV is electrically intact, but simply dirty and not opening on command.
Additionally, has any work been done on the car recently?
Suggest checking idle stability by cracking the throttle plate using shims behind throttle stop. Can you achieve a stable idle?
Also what happens when you pull the connector to the IACV?
That's exactly how mine acts, and the shop told me it's lost compression in 2 of 4 cylinders, aka engine is gone. Mine did die on me while being driven, but that's the only way it'll restart and the way it acts now. No idea If related to yours. This is a 2003 4 cyl.
rambleongirl
Aug 10, 2009 04:21 PM
scansbar
May 18, 2009 03:24 AM
anymore suggestions?
