Will I Burst Into Flames??
Old Aug 21, 2010 | 11:56 AM
PhoenixAccord's Avatar
Default Will I Burst Into Flames??
I have a power steering leak that is causing some smoke when it hits my exhaust manifold.
I know I need to replace the power steering high pressure line but I'm not sure I can drive the 15 miles to my mechanic without bursting into flames. Does anyone know about this or how risky this can be? At this point I don't see any evidence of leaks on the ground when I park and the drip is not constant. Maybe every few minutes? hard to say.
Wondering if it's worth ponying up the 80 bucks for a tow.
2004 Accord Coupe EX 6 cyl
Old Aug 21, 2010 | 04:39 PM
troycifer's Avatar
power steering fluids flash point is at 170 degrees C or 340 F. it is a risk. the fluid its self is hard to ignite but the toxic vapors produced(the smoke you see) can ignite at a lower temp. in the summer(now) i wouldnt drive more than a couple minutes. so i'd recommend a tow. look for friends with car trailers first though.
Old Aug 22, 2010 | 08:16 AM
mitsudave's Avatar
Mechanic might give a free tow if they're the ones fixing it.
FlyLow
Mar 16, 2008 12:08 PM
GodMachine
Jun 8, 2006 05:50 PM
St3v3
May 14, 2006 04:05 AM
marbro
May 12, 2006 04:29 AM
vdabis
May 11, 2006 12:27 AM
