Window Relay Location
Hey 69sixpackbee,
The power window relay is on the passenger side under dash fuse relay box. You are going to have to remove the lower panel to see it. It is a little difficult to get to it. The relay is on the passenger multiplex control unit. There are 3 of them one is an accessory, the other is for rear window defogger and the other is for the power window.The power window and accessory are the same size. I hope this helps you. Let me know if you need anything else as I have the same car. I even have a spare relay LOL.
