window won't roll up or down. Help!!!!!
Old Nov 15, 2006 | 09:18 PM
92tealaccord
Default window won't roll up or down. Help!!!!!
I have a 92 accord 4dr. The driver window has been rolling up and down pretty slow for a month and then today i rolled it down and it wont go back up. When i try to roll it up it makes this loud vibrating type of noise from the inside of the door. does anyone know what is going on and how to fix it?
Old Nov 15, 2006 | 09:23 PM
sir_nasty's Avatar
Default RE: window won't roll up or down. Help!!!!!
sounds like the power window motor is shot, or the cable that controls it is frayed and getting stuck inside the motor.... either way it's probably time to replace it... I bought my motor from www.1aauto.com (or www.1aautomotive.com can't remember the exact address) and that was the cheapest I found it with a lifetime warranty for like $65.00 or so (shipped) you could remove the door panel and inspect it further then manually push the window up and wedge it into place for a temporary fix.... regardless of what's going on you're probably going to have to pull the door panel off
Old Nov 15, 2006 | 09:32 PM
92tealaccord
thanks a bunch for your advice. Im gonna order the motor today but was wondering about the quick fix you recommended. You said that i could push the window up from the inside. How exactly do i do that? i tried pulling on the window from the top but it wouldn't budge.
Old Nov 15, 2006 | 09:34 PM
sir_nasty's Avatar
you'll have to remove the door panel and push the window up into place then secure it there somehow (I just wedged a stick in temporarily)
Old Nov 16, 2006 | 06:21 PM
ivrex's Avatar
i have the same issue on my 95 4 door passenger side, ill be fixing it myself but im not sure how to remove the door panel, who knows how do take it off?
Old Nov 16, 2006 | 06:34 PM
sir_nasty's Avatar
How about a full tutorial?
Here ya go!
https://www.hondaaccordforum.com/m_16927/tm.htm
I wrote that up right after I did it so if you have questions let me know
Old Nov 16, 2006 | 06:43 PM
ivrex's Avatar
many thanks
Old Apr 9, 2012 | 12:20 PM
ccoan's Avatar
Hey there, sir_nasty, I was so excited to find your guidance about this problem. I clicked on your link above:
and it's not working anymore. Can you please point me to the place where I can read it? Thanks!!
Old Apr 9, 2012 | 02:25 PM
djkurious
Sep 2, 2013 03:20 PM
savoiu
Aug 28, 2012 11:12 AM
rubberducky101
Feb 17, 2012 08:03 PM
kevin.neisler
Dec 14, 2011 11:02 PM
crvone
Jun 13, 2011 11:45 AM
