Windshield mirror plug wires
Old Aug 14, 2024 | 11:57 AM
Tinytanic1's Avatar
Default Windshield mirror plug wires
2017 Accord EX-L, 1.4L 4cyl, A/T, 4dr.
I’ve got two problems.
First, the wires to the plug for the windshield mirror need to be re-pinned/fixed. How/or what tools needed?
Second, the upper center display screen is blank. It is backlit so it has power, just no information on it. All fuses, interior/exterior, are good.
Windshield mirror wires are pulled out of plug
Upper center display screen is blank. Haven’t found any bad fuses.
Old Aug 14, 2024 | 03:52 PM
For the mirror, you'll need a pin or needle to release the broken wire pin from the connector. If you are good with an xacto knife, you may be able to reuse the old pin. If not, you can try finding the whole connector with some of the wire harness, then solder the wires together appropriately.
Tinytanic1
Aug 21, 2024 06:50 AM
Chiga
Feb 25, 2012 08:53 AM
streetwise
Aug 3, 2009 10:24 AM
bambooyou
Sep 1, 2008 11:21 AM
millpond
Jan 11, 2007 03:40 PM
