Wipers INT speed stopped working
Old Oct 9, 2011 | 04:15 PM
Jcaleno's Avatar
Default Wipers INT speed stopped working
All the other speeds work fine. The INT speed simply stopped working, or when used, will only move the wipers at some point, then again perhaps 5 minutes later or not at all..again, the faster speeds are working fine..any ideas would be appreciated. Thanks
Old Oct 10, 2011 | 06:14 PM
According to the manuals, check the Common DIY Threads for a link where to get one.
Test the switch and then the relay.
The relay is under the under hood fuse panel-pic has the testing procedure
Attached Thumbnails Wipers INT speed stopped working-4th-gen-int-wiper-relay.jpg
Old Oct 16, 2011 | 11:42 PM
Jcaleno's Avatar
does anyone have instruction on how to check this or use the above provided diagram? I'm clueless as to what to do next...Thanks
Old Oct 17, 2011 | 11:20 AM
Do you have a volt meter?
Old Oct 18, 2011 | 11:57 PM
Jcaleno's Avatar
I don't, but i'm sure my electrician friend does, so i can surely get my hand on one.
Old Oct 19, 2011 | 06:11 PM
Get one, a bit of wire will also be needed. From there we can help with testing the relay....there are other tests so this is just step one.
Old Oct 19, 2011 | 10:30 PM
Jcaleno's Avatar
ok, i'm ready for all the testing. Lay the whole thing on so I can do it in one shot....and thank you for your help!
Old Oct 20, 2011 | 06:37 PM
Go back to the pic I posted (post#2). Test the relay. Is it good?
Old Nov 8, 2011 | 11:48 PM
Jcaleno's Avatar
I didn't find the relay, i have the 10th anniversary 93, could it be elsewhere,? what does it look like? maybe im missing it...got a apic?
Old Nov 9, 2011 | 04:49 PM
See if this helps in locating it.....
Attached Thumbnails Wipers INT speed stopped working-4th-gen-int-wiper-relay-location.jpg
