WONT PASS ECHECK!!!! Help!!!!
Old Mar 8, 2011 | 02:07 PM
Bw0nz1ca's Avatar
Default WONT PASS ECHECK!!!! Help!!!!
okay so im down to the last 3 weeks of my temp tag and CANT NOT pass echeck,i got a 95 accord with the f22b1 2.2 v-tec, MT and 170,xxx miles. all the elements are pretty high, the HC(200 over), CO(.05 over) and NO(2000 over) are waay to high. i dont have a engine light on (got it off with a air charge sensor+ O2 sensor). the idle does have large drops at all times but is worse when the engine is cold. drops of 500+ rpm, i was told i should clean out my idle air control valve and my egr... i dont know or dont think i have a catilytic on it either.... so please, anything can hel[p me in this stage..
Thank you!!!
Old Mar 8, 2011 | 02:30 PM
Adler's Avatar
You don't think it has a catalytic converter?!? You might want to consider getting one... Also, see if there are any stored codes.
There are some tricks to get the numbers down a little, but they aren't going to do much if there is an underlying problem.
Do an oil change...
Take a long drive at high speed...
Maybe run some seafoam...
Old Mar 8, 2011 | 10:59 PM
Bw0nz1ca's Avatar
hahaha now i reread that post that is pretty funny about the cat. conv. haha wow and yeah i think im going to try and get a waiver..... even thou it cant pass. iv spent $300 i think thats enough..
VPofOperations
Mar 27, 2014 01:02 PM
bingo296
Oct 15, 2012 09:00 PM
bingo296
Sep 9, 2012 09:56 PM
1995vtecaccord
Apr 26, 2011 07:35 PM
fusionstar
Jun 13, 2009 01:53 PM
