Sponsored by:
Sponsored by:
wont start when engine is hot
Old 06-01-2010, 06:47 PM
bigmlf's Avatar
Default wont start when engine is hot
car starts fine when engine is cold but wont restart when engine is warmed up. if i pinch fuel line it starts and then i have to slowly release line till idle evens out. new fuel pump and filter, also new injecters. 1988 honda accord 2.0 injected.
Old 06-01-2010, 09:11 PM
hondadude's Avatar
Fresh NGK plugs?
check under the drivers seat for codes?
Coolant temp sensor could cause this problem.
Try to start by turning on the key, wait until the CEL goes out, then crank the engine. [full fuel pump pressure gives a better injector spray pattern]
You can let more air in by holding the gas pedal 1/2 way; and if you think it's flooding hold the gas pedal all the way to shut off injector pulse when cranking.
pipo
08-08-2013 12:34 PM
gasface11
07-11-2012 12:33 PM
jstrick
07-14-2010 07:16 PM
88accorn
07-11-2010 09:10 PM
99cummins
06-25-2007 09:59 AM
Quick Reply: wont start when engine is hot
