zzzz sound from tranny
Old Feb 8, 2007 | 03:06 AM
juanortanez031278's Avatar
Default zzzz sound from tranny
i have an accord 96 4cyl a/t ,I hear a zzzzz sound coming from the tranny when my car is shifting from 1st gear to 2nd ( automatic tranny) and all is quite from 2-3-4
any ideas?
thanks
Old Feb 8, 2007 | 03:49 AM
smaglik's Avatar
Default RE: zzzz sound from tranny
hmmm...maybe you could articulate the sounds better? relate it to something? All I think of when I see 'zzzzzzz' is someone sleepin in a comic strip. haha
Old Feb 8, 2007 | 04:13 AM
deserthonda's Avatar
are you positive noise is coming from tranny??? it could also be the exh heat shield buZZZZZZing ,, chk the shield at the catalytic converter
there is also a bulletin 94-041 where at the exh mid pipe you have to replace gaskets. bolts, springs and nuts ,, the mid pipe is the pipe between the frt pipe and the cat convertor
Old Feb 8, 2007 | 09:12 PM
ckebottle's Avatar
Does it kind of sound like an ambulance in the distance? When my tranny went out that's what it sounded like.
Old Feb 8, 2007 | 09:13 PM
ckebottle's Avatar
Old Feb 9, 2007 | 12:03 AM
hondadude's Avatar
ORIGINAL: ckebottle
Was the Ambulance coming to get the transmission?
I'd agree to check for the exhaust Buzz, theRPM probably is up around 1800 when the trans shifts. That is a classic RPM fornoise from the 'B' pipe joint.
bigtex
Feb 21, 2018 11:08 AM
cat2115
Apr 26, 2014 07:49 AM
tranwreck
Apr 30, 2009 09:27 AM
Evlampius
Jul 19, 2005 12:39 PM
