custom cat-back questions
Old Sep 14, 2007 | 01:23 PM
bssmagik83's Avatar
Almost A Senior Member
Default custom cat-back questions
I just ordered a new exhaust. Just some Magnaflow 14851's. I plan on a custom pipe job, but after reading a post ona civic forum (http://www.hondacivicforum.com/m_39893/tm.htm ) about the truth and myths of backpressure, im not sure what i should or shouldnt remove from my current OEM setup. At first I was gonna remove the resonator and maybe the pre-muffler and run 2.25" all the way into a Y instead of the crimped Y that is on the stock setup and 2.25" to the mufflers. Anyone gotany good ideas or expriences?
Old Sep 14, 2007 | 04:07 PM
Shadow1992's Avatar
Default RE: custom cat-back questions
Simple...less backpressure is good. A good exhaust system creats a scavanging effect in the manifold/header because of pressure differentials in the tubes...but that is different than backpressure. For the cleanest exhaust go with around 2.25 to 2.5 for your N/A engine, leave the cat, but remove the rest. The other parts are there for tone and volume control, which i assume you aren't concerned with. Try to have the piping as straight as possible, and when it has to curve or bend, use mandrel bends that are as large a radius as possible. Although you already have mufflers, the straight-through perforated core designs have the smoothest exhaust flow.
Old Sep 19, 2007 | 09:47 AM
sUbLiMe96's Avatar
Go with a 2.5" all the way....I would also look into purchasing a Pre-Fabricated Y-Pipe...MagnaFlow makes a Real Nice peice which I am actually using on my setup.
Old Sep 19, 2007 | 10:32 AM
falkore24's Avatar
I'm thinking about removing a muff and pipe & capping the Y. See what kind of torque gain I get and make people think it's a 4 cy l[sm=badbadbad.gif]
benzilla69
Jun 28, 2010 12:56 PM
Chris Fredricks
May 26, 2009 08:16 PM
chenglinlee
Feb 27, 2008 02:26 PM
pyaarawala
Jun 1, 2007 01:19 PM
sir_nasty
Mar 10, 2006 04:25 PM
