eBay cat
Old Dec 6, 2006 | 11:23 PM
poser_pilot6
Default eBay cat
When I do my exhaust, sometime in the next three or four months, I want to do the full system. I have my header picked out, my exhaust pretty much decided on (at least narrowed down to two or three choices, just debating how much I want to spend), but I want to replace the cat also, since Im doing the whole rest of the exhaust. I found this cat on eBay...
http://cgi.ebay.com/ebaymotors/94-97...QQcmdZViewItem
It seems kind of shady to me, like WAY too cheap. I dunno. Obviously its not really emissions compliant or it wouldnt say "off road use only." I dont live in an area with emissions tests though, so would that be a factor? If this deal is bunk, can anyone recommend a good high-flow cat? Thanks all.
Old Dec 8, 2006 | 02:00 AM
Slusher's Avatar
Default RE: eBay cat
Yeah, thats just a resonator tube, there is no catalyst system in there. That will just replace your cat with an open tube. To each his own but I would leave your cat or get a real high flow one.
Old Dec 8, 2006 | 02:41 AM
tom15425's Avatar
Yeah, I hear good things about both random tech and magnaflows high flow cats. As stated above, the really cheap ebay ones you see are just test pipes.
Old Dec 9, 2006 | 02:42 AM
poser_pilot6
I figured a cat for like 15 bucks was bs. I just figure that since Im going to be doing the header and cat back all at once, I want to get a better flowing cat also. Tom, I'll definitely check out those two you recommended, thanks!
Old Dec 9, 2006 | 03:25 PM
19Accord97
well if you buy a cheap high flow cat andbegin to start smelling a not so normal smell....well there you go! No cat, not to mention the people behind you wouldnt be to thrilled[8D]
Old Dec 10, 2006 | 10:53 PM
94scaccord's Avatar
they way i look at it .. your not going to be racing any vipers or anything.. you know.. so why pay the extra money for an actual high flo racing cat... if you are going to get header back you just need to make sure that all of you pipes are the same size so that one part of your system isn't restricting or conflicting with all of the others.. i have an exhaust system that i have had for a long time.. added a header.. and now adding a cat.. but i made sure to not get them to conflict.. no matter what you do with your cat.. your only going to gain 1-4 hp probably front it just by replacing it from the factory one.. so not a noticible differenct.. i say get the cheap ebay one and call it a day..
Old Dec 12, 2006 | 12:15 AM
nusdogg's Avatar
thats hella cheap.. lolol i dont really trust those kind of pipe, especially off ebay.
benzilla69
Jun 28, 2010 12:56 PM
pyaarawala
Jun 1, 2007 01:19 PM
sir_nasty
Mar 10, 2006 04:25 PM
1HOTTSHOT
Jul 16, 2005 05:47 AM
toicy4ya
May 11, 2005 02:15 AM
